Activities Widget Issue on Dashboard
Hi All
I am wondering if anyone else is having the same issue with the Activities Widget on the Dashboard page.
The last two days the map on the widget has dissappeared, as well as the segment icon, and been replaced with a heart rate graph.
Scrolling back, the map is still present for activities before the 2 days, and all is good on the full page of the activitiy
Is there anything I am doing or is the another little bug in connect?
  • I'm seeing the issue today. Some activities widgets aren't working for me and the activity bar chart doesn't include my activity today.
  • 4/5/17 issues...
    I am also seeing todays Run not being included in any of the reporting graphs.
    I tried deleting and re-importing the activity....no luck
  • Everything's back to normal for me now.
  • No maps in Activity tile
    I am having the same problem, first I uploaded an activity from my Fenix 3HR, no map, then I tried my Edge 810, still, no map, then I deleted the activities that I uploaded and I removed the Activity Tile from Garmin Connect closed the browser, relaunch the browser added the Activity Tile and low and behold, nothing, nope still didn't work, no map. Hope that this is fixed soon. It made it simple to identify different activities visually. A HR graph all looks the same.
  • Hope that this is fixed soon.
    I wouldn't hold your breath on that, its been an issue for about a month now. Cant believe this is so complicated to fix!!
    The map's back!
    Was on a run today and uploaded the activity shortly after 7pm. At first, I had no luck, only the HR graph was shown. But as by now, I logged into connect again and the map was back! Didn't change anything - magical bugfix :p
  • Fixed for me too. My ride from today showed as the HR graph earlier, but now shows the map as per normal.
  • What about runs for prior to today?
  • Fixed for me too.
    I wouldn't call it fixed. Further impact arising from the problem has been arrested, in that new activities uploaded are not affected. Activities uploaded in mid-to-late March continue to exhibit the same symptom.
    As an experiment just now I went into Garmin Connect online, identified a run completed and uploaded on 29‑March 2017 (which showed the HR graph instead of the map in the Activities widget), and exported the original as a FIT file. Then, I deleted the activity from Garmin Connect, and restored it by importing the FIT file.
    The result is that the (restored) activity still only shows the HR graph and not the map in the Activities widget.
    So, no, the problem is not fixed.
    Ha! It gets worse.
    I identified two activities – one from 9‑March, for which the map was shown in the Activities widget, and the other from 10‑March, for which the HR graph was shown. I exported the original data to FIT files, as well as found the FIT files for them on my FR630. I then deleted both activities from Garmin Connect.
    Upon restoring them using the FIT files found on my FR630, the map is not shown for either of those activities.
    I deleted both activities again.
    Upon restoring them using the exported FIT files, the map is not shown for either of those activities.
    The problem is definitely not fixed, since there appears to be no way to make the map show for the activities in the Activities widget, even with manual intervention by the user.
    back to HR graph again
    unfortunately, on today's running activity, the HR graph is back again. for yesterday's run, the map was shown (when I was logged on yesterday evening), for today's run, the HR graph is shown again. The running activity from yesterday shows the HR graph instead of the map again. don't know what they are doing right now :/
