I have tried to connect myfitnesspal to a couple of times now but weight won't sync. No matter what i try.
@Gamrin, please fix this or read weight data from the ios health app. Should be trivial to…
After some failures i managed to find not a clean way to sync weight from Xiaomi Mi Smart Scale to Garmin connect
Xiaomi Mi Boody Composition Scale adds weight to Mi Fit app >
Mi Fit app is synced…
Hi guys I'm the author of the Mi Scale Exporter. I'm happy to see that it works well (in most of scenarios) and thanks for all the feedback.
Originally the app was for my own purpose, so it is…
Hi Łukasz,
Thank for your effort according to this app. I have a question: can you consider the possibility to solve problem with two-step garmin account verification? Due to ECG I turned on this feature. Unfortunately, it is permanent :-(. Now your app Miscale Exported do its task also in two-step - after first attempt I have to put verification code (sent by email) and try to sync again. I have in mind "remember this device" or something like that.
Thank you again,
serdecznie pozdrawiam,
Krzysztof
Please check your data (Age/Height/Gender) in Exporter app and in Zepp Life. It should be equal.
However, xiaomi's weight algorithm is not known, so the data achieved may be slightly different from that presented in Zepp Life, but the weight or BMI should be the same
I'm not sure all that workflow is better than just jotting down four numbers manually each time you weigh.
