Garmin Connect incorrect data after manual upload
Hi,
I am using Dakota 20 and I had no problems with uploading and analysing my workouts till yesterday.
After uploading my last three rides from Dakota (gpx files) I am getting correct distance and total time spent, but I have no movement time, no avg speed, no max speed, graphs based on time are empty (switched to distance are showing correct),
At first I thought that it was a damaged gpx but today's ride show exactly the same.
What is more, when GC syncs with Strava al looks perfect there.
Is someone experiencing any similar issues? What can I do now?
I tried to convert gpx to tcx and upload then but the problem remains.
Thanks for any help.
Regards from Poland
Mariusz
    Check out one of the very recent threads I have created
    Apparently, the GC crew are aware of this problem.
  • Thanks.
    Where did you find that info? I would be able to follow that thread.
    Maybe they will find some temporary workaround :)
    Just go nine threads down the list from the one you created
    At least the trip distance in GC is correct, so if you do not care much about the speed, this should be enough for the time being. They will fix it, do not worry.
