Problem with GPSMAP64s tracks and Garmin Connect
Hello everybody!
I have Garmin GPSMAP 64s and Garmin Forerunner 610.
After some activity I want to see it on Garmin Connect, that'ys why it exist. ;)
With Forerunner I have no problems with syncing, but GPSMAP make me lot of problems.
First, they didn't want to sync at all. So I had to upload my activity manually. Ok, it worked.
Then, there was few times when syncing worked.
And after that, syncing doesn't work again, to be more precise, it works but the track is wrong, and now, I cant upload my activity neither manually after I edit it.
That tracks looks good on my GPSMAP, or on some other web pages, for example http://www.bikemap.net, but when I try to upload it on Garmin connect, the track shows wrong, or the page can't upload it at all.
The problem that occur, sometimes, is that after hiking, for example, I finish a tour, I shut down my GPSMAP, but when I came home and try to sinchronize track, it add to it my home point so now the track isn't the right one any more. And Garmin Connect doesn't have the possibility to edit the track.
I tried to save activity (track) right after tour, or put it in Archive, but no help. This is situation now, I said, few times it worked good, now it doesn't.
Then I tried to edit this track on some other web site, e.g. bikemap, but this gpx tracks Garmin Connect have problem to upload.
So please, can anybody tell me precisely, step by step, what I should do, after hiking with GPSMAP 64s, to upload my track on Garmin Connect, only the hiking track, not driving car points, my home etc ...
Thank you very much and I hope you understand what I wrote here. ;)
  • You really ought to use BaseCamp for your 64 as that will work far better for you. Making Connect work is always going to be hit or miss.
    Ok, thanks. Than I must learn how to use BaseCamp and that needs time ... :/
    Connect is easier for me and I'd like to have everything at one place.
    Pitty that it doesn't work with 64.
  • Well it will work but you will need to manually upload your data.
