For Garmin Connect under "Stats" then Timing you have the option to select pace or speed?
In the APP I see both Pace and Speed?
Not sure what problem you're having unless you're referring to…
On Garmin Connect and in the Android app the focus is on pace. And indeed the laps / split pages only use pace. I want the option to use speed instead of…
BTW, the Speed display and graphs are in Garmin Connect since a longer time. All what you need is clicking the button Speed.
Not sure what problem you're having unless you're referring to speed missing within the lap / split information!
I'm British living in Germany and no one uses Speed for training! - Speed is not accurate like pace hence why it shouldn't be used for training.
On Garmin Connect and in the Android app the focus is on pace. And indeed the laps / split pages only use pace. I want the option to use speed instead of pace on the splits and on the main screen. This is in a nutshell my request:
Please add the option to have speed (km/h or miles/h) as default information for running activities (instead of pace).
This is a fallacy. The definition of speed is distance covered (length in meters) per duration of the interval (time in seconds). Pace is the inverse of this (time divided by distance). So if speed would not be accurate (the outcome of distance / time) than it follows that pace also is inaccurate (outcome of time / distance) and vice versa. Their accuracy is the same because they both use exactly the same measurement units (meters and seconds).
Futher more: It's about having the choice. Speed (km/h) as default running information option instead of pace. For the people who do want to use it. Presented as an option.
Here's another request for speed (mph) as an option. I paddle a kayak and use my Forerunner for training.Which Forerunner model? On the FR235, the user can specify:
- his or her preferences for pace or speed – in Menu»Settings»System»Format»Pace/Speed_Preference – separately for Running, Cycling and Other activities; and
- the unit for distance in pace/speed calculations – in Menu»Settings»System»Units»Pace/Speed
In Garmin Connect online, the default for displaying activity details recorded as Other using the FR235 is speed, but there is the option to switch the speed chart and summary values (but not in Splits) to pace when reviewing an activity. If you manually change the activity type to Whitewater Kayaking/Rafting, the default is also speed.
(To see pace values in Splits, you need to manually – if temporarily and reversibly – change the activity type to Running.)
How can I view my speed instead of pace when reviewing an activity?
Not sure about the iOS app, but on the Android app you can tap on the second tab (a document symbol) on the respective Activity page, and you get a screen with both pace and speed values.
