Problem with "Stay on Road" Courses using Openstreetmap
In Garmin Connect, I'm unable to create courses when using Openstreetmap and "Stay on Roads" selected. After clicking on the start point and then clicking on an additional point I get a "Loading" message that stays forever. It works fine if "Stay on roads" is de-selected. It also works correctly using Google map instead of Openstreetmap. There appears to be an issue calculating the on road route between the two points using Openstreetmap only.
This has worked successfully in the past, but now seems broken. I've tried it using 3 different browsers and on 2 different laptops and the problem is the same each time.
Anyone else having the same issue or know how to fix it?
