- Would it be possible to keep your speed info displayed on the map (data overlay) during horseriding? Similar to cycling.
If you tell during horseriding, then I assume you are referring to the watch, since the app (you are posting to the forum for the app) does not show any speed or pace info during activities. If you really mean the watch, then you can customize the default screens in practically any way you wish, on most models. You did not reveal which model you own, so I cannot look up the link in the respective user manual for the data screen customization, but should you have problems finding it there yourself, post a question in the forum for your respective watch model.
Thanks for your reply, but no, this is not what I mean. These pictures might help.[moderator removed] "Horsebackriding gives a red line with no further info on the speed. When I pretend horseriding is cycling, Garmin gives me the speed info during the track. Hope you could add this info to the horseriding layer as well. Especially for endurance riders this is very valuable. Thank you.
We cannot, you are just on the user forum here. You have to ask Garmin. Try suggesting it to them at Share Ideas | Garmin
Thanks, will do. could someone remove this question here?
Moderator: 3618465, we can remove this thread, but we usually prefer to keep it so that other users with a similar question can be helped. I've removed the map, in order to obfuscate private information.
