Strength Activity Problem when adding weight to exercise
I’m on Connect 4.74.0.30 since update recently.
I’ve got a problem when updating exercises in Strength Activity.
I do a weights session at gym and track it on Strength Activity using Fenix 6X. Later, I edit the activity in Connect mobile. All has been fine for past 7 years. Since update when I add the various types of exercise, weights lifted etc the exercise name becomes blank if I add a weight unless there is ‘weighted’ in the name of the exercise.
Eg I select edit and add Leg Extension, 30 reps and 50 kg and move to add next exercise. The name ‘Leg Extension’ disappears but reps and weight remain. I then need to edit it and add ‘Weighted Leg Extension’ and then it remains. It happens on most exercises I add in. It’s annoying and I can work around it by selecting ‘weighted’ names but it needs fixing.
  • Same problem, specifically with Leg Curls.
  • Please update to Garmin Connect app version 4.74.1.3 and test again. If the issue remains, we will want to investigate further. Let us know if we have permission to contact you via email.
  • I’m having the same issue. For any exercise that defaults to “Body” as weight, if I add an amount for weight, it goes blank.
    Also, anytime I edit and save a workout, the app crashes. This has been happening since the last update.
  • Garmin - Sara
    Thanks for your response. It’s ok for Garmin reps to email me and access my account.
    I updated Connect and did a weights session today. The problem remains in the case where the default weight is ‘body’.
    Ive include 2 screen shots and item 7 leg extensions caused the issue. It is fine if I add reps but when I change ‘body’ to 50 (for example) the name ‘leg extension’ changes to ‘choose an exercise’
  • I too have the same issues as reported above with the exercise blanking out and returning to "Choose an exercise" as soon as a weight is entered as well as the weight being incorrectly displayed, e.g. I enter 10.0 pounds and it displays at 10.1.  The other issue is upon saving any exercise it gets stuck returning to "My Day".  The running man seems to run forever.  I have already updated to 4.74.1.3 and these issues persist.  Please contact me to troubleshoot the problem.
  • Thank you all for the reports. We have released the Garmin Connect app version 4.75 to resolve this issue. If you encounter the same issue after installing the latest update, please create a new Thread or contact Product Support.
