Garmin connect is not calculating VO2max
Hello there.
I was using strata before and now are using Garmin connect and Garmin forerunner 630.
I wanted to sync them. I did it and on strata all my Garmin workouts showed up. But the workouts I was recorded in starve before did not show up in Garmin connect.
So I went to strata and download each workout manually with gfx. Upload them to Garmin connect.
All trainings were running. When I opened the activity list all training was "other". I manually change them to running and save.
The problem is it is not changing my VO2max and show only 2 activities that counts into VO2max calculations.
Is it possible somehow to solve this?
Best regards,
Mikus
  • Strava do not sync to Garmin Connect. That is why you didn't get the activities to Garmin Connect.
    Why you had to change type manually was likely because the type wasn't included into the files. That is a Strava issue. Talk to them if you want that changed.
    To get VO2 max values you need to log activities with your Garmin device. You just need a few runs with a Garmin device to get your VO2 max value so don't worry about your historic values.
