Garmin Connect not syncing to Strava if Strava also recorded same run
Hi All,  My Garmin syncs to Strava just fine when completing a run.  However, I noticed that when I am also recording the run in Strava, the run from Garmin Connect doesn't sync to Strava.
The sequence is this: start recording on Strava and Garmin Fenix 6 at the same time.  At completion, press stop on both at same time.  Save run on Strava.  Then save run on Watch once the Strava one is done.  When I do this, the Garmin run doesn't sync to Strava.  Has anyone else had this?  Is this expected behavior?
I am recording simultaneously because I have been debugging my distance measurement issues and need to simultaneously look at a couple of sources.  Is there another way for me to use accomplish this?  The primary source I want sync'ed is the Garmin.
Thanks!
