Why is my max speed so incorrect?
Why is my max speed so incredibly incorrect.  The rest of the information is correct.
    0 Former Member over 5 years ago
    If you pause a an activity, move to a new location before resuming it is possible that the recording device will calculate a speed between the two points. Or this could happen if GPS lock is lost (quite possible with the pause when not moving) and you move to a new location before it re-establishes.
    For example:
    You stop and pause the activity, GPS lock is lost,  you walk two hundred meters down road, resume activity, the GPS has not re-established yet the time starts and then Gets the location,  the device sees that you have moved a distance in a very short time period, hence a high speed.
