ATTN: iOS Users with issues after updating to iOS 13
I Am Having Issues with My Garmin Watch After Updating to iOS 13 on My iPhone
With the released of iOS 13, some changes in the way that your Garmin device communicates with your phone have changed.  Review the following symptoms which should solve your issue.
The Garmin Connect app displays the message "Bluetooth is turned off"
iOS 13 requires Bluetooth Sharing to be turned on for the Garmin Connect app.  Below are steps to enable this setting.
  1. From the iPhone, select Settings
  2. Scroll down and select Connect
  3. Toggle Bluetooth Sharing on
NOTE: For the best user experience with your Garmin device and your phone, the Location setting should be set to Always and all toggles should be set to on.
I Am No Longer Getting Smart Notifications on My Garmin Device
To correct this issue follow the steps below:
Check Bluetooth Settings
  2. Select Bluetooth
  3. Under MY DEVICES select the i icon next to your Garmin device
  4. Toggle Share System Notifications to on
Check Notification Settings
  1. Select Notifications
  2. Set "Show Previews" to Always
  3. Under "NOTIFICATION STYLE" select Messages
  4. Under "OPTIONS" set "Show Previews" to Always (Default)
Update your phone to iOS 13.3.1
Why Do I Need to Keep Signing Into the Garmin Connect App on My Phone?
Garmin is aware of an issue where the Garmin Connect app requires you to sign in when you open the app on an Apple phone.  This can occur when:
  • The phone is rebooted
  • The battery on the phone runs out of charge
  • Some reports of the issue randomly occurring
Apple has released a software update for your phone that corrects this issue. To download and install  OS 13.3.1, refer to the following Apple instructions: Update your iPhone, IPad, or iPod Touch
    0 Former Member over 5 years ago in reply to Garmin-Blake
    I did this. Still not getting notifications.
  • I’ve discovered my main issue and maybe it’s something you can address in an update. I can pair my iPhone and Fénix3 and it works fine. However when I lose connection (I walk too far away from phone) and then regain it, I get no notifications. Even though the watch shows connected on Bluetooth and I have the green dot on Connect app, the watch will not sync.
    My fix, which is becoming tedious and annoying, is to re-add the watch all over again going through the various steps you’ve outlined. If there is a way you can address this loss of watch abilities during reconnecting, maybe you can solve a lot of the issues...starting with mine.
    Hope something happens soon.
    0 Former Member over 5 years ago in reply to Former Member
    Same here
  • I have weirder problem. The notification works for me but hr data wouldn't sync, only steps and others. I'm on Vivoactive HR pairing with iPhone Xs iOS 13.1.3 ...
    • Trotz neuem iOS Update 13.1.3 und Neuinstallation von Garmin connect mit neuem update von gestern, sowie werksresett der fenix5 werden keine Mitteilungen angezeigt.
    • Wann werden diese Probleme gelöst?
    My workouts download but nt my steps or heart rate.   My iPhone has the latest update 13.1.3 ....
    Please help!
    After the connect update yesterday 10/17/19, my device won’t transfer the data to the connect app. Not sure how to fix the issue
    Hello, my Garmin 1030 pairs with my iPhone 11 however will not sync.  All other items work.
    Yeah mine and the wife’s also won’t stay connected or sync most of the time we have to now do it via WiFi from the watch. This has only happened since the update 2 days ago yet Garmin have either not tested the release or don’t care enough to fix it already.
    I can't believe a month later this is still an open issue. Garmin is really dropping the ball on us.
