VO2 Max "Current" Field is not updating from my Fenix 5X
Weirdly, my watch (Fenix 5x) lists my current VO2MAx as 54, but on Garmin connect Mobile and Gamin connect, it still lists as 46 and has not updated since June 28...the historical fields seem to be correct but the current field is not. Is this a watch issue? a GC issue? When will it be fixed. Am running latest firmware 4.10 (not beta). Any thoughts or advice?
Tags: None
  • (Sort of) the same here. Connect website lists last VO2Max as July 24, the IOS app has a reading from yesterday July 26. Everything else is synced. Where do you find VO2Max on the watch itself?
  • Same here I think.
    Vo2Max on watch is working and was updated on last run 01 aug 2017
    Vo2Max on garmin connect was updated 24 July 17. I am training every day.
    Vo2Max 4 week graph on iphone is show some values. Last one is 29/30 July (hard to see dates)
    Training Status both on iphone/web browser has been showing Vo2Max fairly good until now, but it stoppet working 30 July
    https://connect.garmin.com/modern/report/-1/all/last_four_weeks
    You can see the last Vo2max on the watch by pushing the down button until you reach the training status widget. then you push the right top button to enter into details and the vo2max will show. The Performance widget needs to be installed and should be by default I think
    hi there - same issue here. Any resolve yet? And sometimes I see performance stats in the app and the last few days it has been hit or miss. See attached screenshot where last update was July 25 - I have had 10 runs since that....
    Hi, 31 juli did my vo2max stop updating to GC. It works fine on my fenix 5x watch and is correct in everything ecxept the graphic side on GC. It stopped on 46 and I have 49 on watch. lactic threshold does not update either. Wrote to Garmin support a week ago but no answer yet.
    Hi! Same issue here. Nice VO2max progress on my Fenix 5x, but Garmin Connect Current VO2max stopped updating a few weeks back. When looking at the development over the last 4 weeks, however, I see the chart is updated.
    Hi there, any update o about this issue?
  • Did this work itself out, or still an issue? I have it now, and some others do too.
  • Hi. Did this issue work itself out?  Conversation seems to trail off. I have the issue today, and some others do too.
