Xiaomi 17 Pro Max / HyperOS 3 loses Fenix 6X Pro Bluetooth pairing after every phone reboot
Hello,
I am experiencing a reproducible Bluetooth pairing problem between my Garmin Fenix 6X Pro and a Xiaomi 17 Pro Max running the Chinese version of HyperOS 3.
Device configuration
- Phone: Xiaomi 17 Pro Max
- HyperOS: 3.0.304.0.WPBCNXM.C06
- Android: Android 16
- Watch: Garmin Fenix 6X Pro
- Garmin Connect: latest available version
- Phone ROM: Chinese ROM
The Fenix 6X Pro works normally after pairing. Garmin Connect connects to the watch and synchronizes correctly.
However, every time I restart the Xiaomi phone, the Bluetooth pairing with the watch is lost.
The behavior is very specific:
1. Pair the Fenix 6X Pro normally.
2. Garmin Connect connects and works correctly.
3. Restart the Xiaomi 17 Pro Max.
4. After the reboot, go to Android Bluetooth settings.
5. The Fenix 6X Pro appears under "Rarely used devices", but it is no longer paired.
6. If I tap the watch to connect, the phone asks for the Garmin pairing PIN again.
7. After entering the PIN, the watch becomes paired again.
8. I open Garmin Connect and the Fenix 6X Pro immediately appears as connected and works normally.
I have reproduced this twice after two separate phone reboots, so it appears to be completely reproducible.
Important observation
The phone does not completely forget the watch. It still appears under "Rarely used devices", but the Bluetooth bonding/pairing information seems to be lost.
This makes me think the problem may be related to the Bluetooth bond persistence in HyperOS 3, rather than Garmin Connect simply being killed in the background.
I have not performed a factory reset of the watch or reset the phone's network/Bluetooth settings because I wanted to document the reproducible behavior first.
There is also another recent report of a very similar problem involving a Fenix 6 Pro and Xiaomi running HyperOS 3, so I wonder whether this could be related.
Could Garmin please investigate whether this is a known compatibility issue between HyperOS 3 / Android 16 and the Bluetooth pairing used by the Fenix 6 series?
I would also be happy to provide additional information or logs if required.
Thank you.
