Hi - I have a Garmin VenuSq2 and I bought the HRM Pro Plus as I'm starting to actively run again. I connected the HRM to the app and to the watch - the watch registered the sensor when I started a treadmill run. According to the HRM specs, I should be able to see my ground contact time, balance, vertical oscillation, vertical ration, etc. And those should be in the activity under a tab called Running Dynamics or Metrics. However, I dont see either of those labels. I see Overview - Stats - Laps - Charts - Gear. Under Stats, the only running dynamics I have are avg run cadence, max run cadence, and avg stride length. So where would I find the other info?
