my exercise load is 0 after a power loss during run
When the device turns off due to low battery, I can turn it on again and decide whether to continue the session or save it.
Unfortunately when I turn it back on I find the training effect at zero, while all the other data are correct (km, height difference, fc) Why does this happen? how to fix this?
THANKS!
  • As far I know there is no remedy for that. I have the same problem few weeks ago.
    My later test has showed partial solution. After turning on watch again, you should continue session for few minutes. I have simply walked several hundred meters and then only save it. In this moment I have some training effect data. Not as should be but at least not complete zero.
    But anyway you should not be worried much as numbers will eventually get to normal after one week.
