Bonjour, j'ai une garmin 6s pro et j'aimerais avoir pour mon jogging l'analyse de l'oscillation verticale...mon conjoint la sur la sienne et moi pas...comment faire?
Merci
Merci
.. voici un peu plus d'info sur les données de Running Dynamics sans un capteur external :
new Garmin WRIST Running Dynamics - Which models will get it? (the5krunner.com)
Le F6 n'est pas sur la liste à ce moment
... et effectivement, voici la liste des montres avec le support de RD sans un capteur external, directement de la part de Garmin :
Garmin Watches That Support Running Dynamics | Garmin Customer Support
Watches Compatible With Wrist-Based Running Dynamics
The following watches will support wrist-based running power to calculate five running form metrics without the use of a running dynamics accessory. For all six running form metrics, you must pair your watch with an HRM-Pro series accessory or other running dynamics accessory that measures torso movement. For information on wrist-based running power, see your owner's manual.
NOTE: Ground contact time balance is available only with a compatible running dynamics accessory.
- D2 Mach 1
- Enduro 2 watch
- epix (Gen 2) - Standard Edition| epix (Gen 2) Sapphire | epix (Gen 2) Porsche Edition watches
- epix Pro (Gen 2) - Standard Edition 42mm and all other models in the epix Pro (Gen 2) series
- fēnix® 7 Standard Edition watches and all other models in the fēnix 7 series
- fēnix® 7 Pro - Solar Edition and all other models in the fēnix 7 Pro series
- Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music watches
- Forerunner® 265 | Forerunner® 265S watches
- Forerunner® 945 LTE watches
- Forerunner® 955 | Forerunner® 955 Solar watches
- Forerunner® 965 watch
- MARQ® Athlete (Gen 2) watch and all other models in the MARQ (Gen 2) collection
- tactix® 7 - Standard Edition and all other models in the tactix 7 series
