I think it would be a great idea if the VO2 max calculator would take into account that someone might be running uphill. My VO2 max is pretty bad because I am always climbing a hill when running.
Yeah. That's the problem. My watch has an altimeter but when the VO2 max is calculated, altitude doesn't play a role. The only reason I have a high heart rate while running in a relatively slow speed,…
Are you sure that VO2 max is calculated from pace, heart rate and elevation change? If that's true then a slower pace going uphill should not lower the VO2 max values. That's my understanding at least…
Yeah. That's the problem. My watch has an altimeter but when the VO2 max is calculated, altitude doesn't play a role. The only reason I have a high heart rate while running in a relatively slow speed, is because I'm climbing the hill. But the calculator only sees that I'm running slowly with a high heart rate.
When you look at your run in Garmin Connect, does it show the altitude increase? Does the watch show it when you look at the activity there?
Garmin's algorithms have taken up/downhill into account in running VO2max for several years (on watches with barometric altimeter like your Venu 2), so I'm pretty sure it's not the case of algorithms ignoring altitude changes. Something else has to be wrong.
But what are you comparing against? Does running on a flat terrain give you better VO2max?
Yeah the watch shows the altitude change. When I'm running on a flat terrain it gives me better VO2 as you say. I had the same problem in the past using a Vivoactive 3. I think trux is right and a trail run function is needed for me to have the correct results.
I have an older watch with no VO2max for trail run (Fenix 5+), so I can't comment on that. But I'm not totally confused the trail run would give any any more "correct" results. The fact is that since running VO2max is estimated from pace, elevation change, heart rate (at least), it's not the "scientific" VO2max (maximal oxygen intake), but rather a number that also depends on things like running economy, terrain hardness, etc. And especially running economy is a factor. So, if you running economy running uphill is worse than running on a flat terrain, that would definitely give you a worse VO2max estimate. I know this from personal experience, since my running economy is definitely worse when I'm running slow. And no surprise, the watch lowers my VO2max after slow runs.
