I just bought a Garmin Edge 1040 but when I use it for indoor Cyling it does not register Intensity minutues, but when I use it for outdoor cycling it does! Why?
From a Garmin Support Center article on Intensity Minutes
NOTE: The Edge Explore 2 is currently the only non-wearable Garmin device that is compatible with the Intensity Minutes feature. Any other Edge cycling unit will not be able to record intensity minutes without the HRM-Pro or HRM-Pro Plus being worn while also paired to the Garmin Connect app.
Source: https://support.garmin.com/en-GB/?faq=pNU9nnDzzGAHmEavp9rpY8&productID=571520&tab=topics
If you are wearing a compatible Garmin watch during your outdoor rides but not during your indoor rides, that could be the reason.
