Hi my cycling activities are not recorded in the intensity minutes on the Connect app? Any advice?
Thanks Pete
The Edge 1030 does not directly support intensity minutes.
However, if the Edge 1030 records heart rate with the activity from an external sensor, you have a Garmin watch that supports intensity minutes, and you have Physio TrueUp enabled on both, this can cause the watch to increment the Intensity Minutes.
Yeah have a similar issue on a 1040 solar. Stupid. Seems when a external HR monitor device is used for example wahoo tickr Garmin won't include it. Pretty stupid tbh as they have all the zone and HR data to make it work. Probably some commercial decision around getting users to buy more gear.
