Hey. I have a problem with Changing weight after my workout. On my vivoactive 4 i cant use comma. and the app has same problem. The Web version works. Maybe I made mistake. Hope someone can help!
Sorry, I did not read properly your post, thought you could not enter your weight. For editing a workout - are you really telling that it does not let you change the weight (not showing the change on the edited page), or that the change does not upload to the watch?
I meant... i created my own gym workout and sometimes i need to change the weight of some exercises. First Problem is cant Use comma in the watch so need to edit After my workout in app but this doesnt work. In web version no Problem in app cant use comma Or dot. It does not save it
I do not undestand at all what you mean by that. Why cannot you use a comma? And where do you need to use it on the watch? Are you editing the workout directly on the watch?
What exactly does not work? I have just tried it, and did not experience any problems. It does not let you enter the new value? Or it does not save the change? Did you tap the SAVE button at the top? Or the edited workout does not get uploaded to the watch?
Yes im Editing on the watch because rep counting and weight isnt always correct. So and how do i get 57,5 KG on the watch. Its always 575 kg. Vivoactive 4.
And because of this i want to edit the weight in the app. But the same. I can write 57.5kg but it always Shows 575 kg.
Hope i could explain better now.
So you are telling, that you type 57.5 into the edit field in GC Mobile, it shows all right there, you then tap DONE, and on the Workout screen there is 575 instead? I am unable to reproduce it. I must be misunderstanding what you are doing. Can you describe it exactly step by step, and attach some screenshots?
