Als ik begin te wandelen beschouwt mijn garmin dit als lopen. Bovendien kloppen de afgelegde kms in garmin niet met de werkelijk afgelegde kms. Hoe kan ik wandelen als standaard instellen en zorgen dat de afgelegde kms terug kloppen?
Kms kloppen niet
  • When you do not start any Activity, the watch measures the distance by an estimate based on the number of steps and the average stride length. You have to start the Walking, Hiking, Running (or whatever else) Activity to actually start the GPS device. Type the name of your watch into the search box at YouTube, and you will get plenty of videos nicely and clearly demonstrating its basic use.
    0 Former Member over 5 years ago
    Bij mij gebruikt mijn vivosport ook het woord "lopen", maar volgens mij komt het omdat het hollands is ingesteld. In Nederland is lopen hetzelfde als wat wij in België wandelen noemen. Het Vlaamse "lopen" is voor Nederlanders hardlopen of rennen.
  • OK, you did not tell that you use the Vivosport. This device does not have GPS, so it cannot measure the distance. It can only estimate the distance by the stride length. By default the algorithm uses the average stride length set on the basis of your height, age, and gender from your user settings. You can calibrate and set a custom stride length. As I already wrote, on YouTube, you can find plenty of videos explaing the use. For example the following one demonstrates how to calibrate the stride length on Vivofit (I guess it may be pretty the same on Vivosport):
    https://www.youtube.com/watch?v=Er1duXK4zZY
    For further questions, please use the Vivosport forum, and post preferably in English. Most users won't bother reading and translating your questions in Flemmish, hence you'll have little chance to be helped.
