This Connect app is fairly mature now, but it truly sucks. I don't even bother entering data anymore because it can take almost as long as the activity because your data entry dials are so extremely limited. God forbid you're into the hundreds or even thousands and you'll spend 10-15 minutes entering simple numbers.
Why are your scrolling dials so limited? Why do I have to scroll on one dial from up to the thousands?
One dial for each place. This shouldn't be too hard. It is 2019 and all. Something this user unfriendly should not even exist at this point. One dial for each placement. You could have it up to the hundred thousand mark. Hundred Thousand, Ten Thousand, One Thousand, One Hundred, Ten, One, Decimal, Tenths, Hundredths. 0-9 for each.
Again, this should be basic design 101 for user friendliness. Especially if you're not going to give us manual data entry that automatically adds the decimal point and goes to the hundredths.
Can we get an update ASAP? And while you're at it, can you work with the commercial gym equipment (bikes, treadmills, ellipticals) and lets get a little 2 way interaction so your results from the machine get uploaded to the app automatically? Again, 2019. It's just a shame something like this isn't standard by now. Especially when many are using their watch for HR and not using straps, but the machine can't interact with the watch to get the info.
