Bluetooth Sync Problem: FR220 to Nexus 4
Hi!
I've got a brand new Garmin Forerunner 220 with the newest firmware (updated with the Garmin Express Windows program) and a Google/LG Nexus 4 Android phone with Android 4.4.4. Pairing the FR220 with the phone always only works for once, but doesn't re-establish a connection later.
So, I turn on Bluetooth on the phone and on the FR220. In the Garmin Connect Mobile App it shows my FR220 and that it is waiting to connect. On the FR220 I select "pair", then it shows a 4-digit number. After a few seconds, on the phone, the same number is displayed and I can pair the two. Then all new activities are synchronized (which takes a few seconds). Everything perfect. Then I switch off Bluetooth on both devices to save energy.
The next day I activate Bluetooth on the phone and on FR220. On the FR220 I do NOT select "pair", because the two already should know each other. Both devices have Bluetooth enabled and searching for each other. But they do not connect. :-(
To re-establish a Bluetooth connection, I have to go through the whole pairing procedure again.
Unfortunately Garmin Express doesn't work on Linux, therefore I have to rely on Bluetooth to sync the FR220 (the first Garmin Express stuff was done on a friends PC, and I don't want to bother him after every activity). This makes the problem even worse.
How can I solve this problem?
Thanks
Johann Glaser
    Bonsoir,
    J'ai exactement le même problème que vous, depuis la mise à jour de l'application Garmin Connect. Dimanche cela fonctionnait bien, cela ne fonctionne aujourd'hui.
    Testé sur Samsung Galaxy S5 et Samsung Galaxy Note 3 et une FR220
    Good evening
    I have exactly the same problem as you, since the update of the Garmin Connect application. Sunday it was working well, it works today.
    Tested on Samsung Galaxy S5 Samsung Galaxy Note 3 and a FR220
  • Thanks for your reply. Unfortunately, updating the Garmin Connect application on my phone didn't improve the situation. Today I struggled for 20 minutes until the FR220 and the phone talked to each other. :-(
