This update can be downloaded with Garmin Express or automatically through Garmin Connect Mobile.
Change Log
- Fixed an issue with some CIQ watch face data fields not updating
Change Log
Has the battery drain issue been addressed?
Garmin tech, is there a provision to pin a software version? If I am on a working version I want the option to refuse further updates that will likely break current functionality. We shouldn't be forced…
does the update with Garmin Express come with conect at the same time, or is it always possible to update there?
have you read the posts related to battery drain issues? Are you alll thinking to professionally address the problem???
@1985260 what exactly is your problem?
Does your VA3 successfully sync with Garmin Connect Mobile app on your phone?
Is GPS turned on - on both your phone and VA3? I believe during sync some GPS-information is transferred from the phone to the VA3.
What activities did you try? Did you try outside without any buildings, trees etc. shielding the GPS-signal?
Phone GPS is on. Watch GPS is on. Watch synchronized with phone app as well as laptop. Tried running as well as walking and navigation. No GPS signal on VA3. Reset, tried again. No joy. VA3 GPS attempted with no trees or buildings. Left for 3 hours no GPS.
Have you tried setting it to GPS+Galileo?
GPS+Glosnas, GPS+Galileo as well as just simply "on". No joy. VA3 was bought in the UK and is being used in RSA. Could this make a difference?
