New Garmin Swim - Missing Laps
Hello,
I am a very long time Garmin running watch and cycle computer user, and recently purchased the Garmin Swim for my lap swimming. I just got the watch on Saturday, and it came with FW 3.4. I updated to 3.6 before going to the pool to test it out. Here is my experience on two pretty short swims (1500 Yards, three 500 Yards intervals in each of the two workouts).
The first workout:
http://connect.garmin.com/activity/410561204
In the above workout, the watch took a while to actually count a lap in the first interval. You can see from the times that the first 25 took a long time. It was short by two laps (50 yards). In the second two 500 intervals, it appeared to be accurate.
The second workout:
http://connect.garmin.com/activity/411144506
I wanted to go out again today and do an additional workout and see if it was just flakey at the beginning. In the above workout, it lost 50 yards in the first 500 interval. In this one, I swam 500 yards and it recorded as 450. Again, after the first rest, in the second and third intervals, it was accurate.
Is this normal for it to miss laps? Most of what I am seeing is people having too many laps. I'm not sure if it is something I am doing when at the wall. Just some background, I don't flip turn. I get to the wall, turn, and push off. All laps were freestyle (expect the drill mode at the end of today's swim).
Anyways, any help or guidance would be appreciated. I know it won't be 100% accurate, but want to make sure there is not an issue with my watch.
Thanks!
    I think the key is to make the first stroke after the push off with the arm the watch is on.
    I wish there is an edit function on Garmin Connect. So we can add or delete incorrect laps.
    Thanks for the tips
    Crap - I just spent a ton of time writing a considerate post analyzing your swim data to illustrate where technique was confusing your Garmin Swim. But the board locked up and I lost the whole damn thing!
    :mad:
    Long story short:
    • I didn't mean to come across as pompous or "I'm a better swimmer than you" and am sorry that's how it obviously came across,
    • You don't need "perfect form" to use the GS, but unlike their running and cycling devices, the GS is a "dumb" device in that it does everything based on accelerometers that tell the watch which way it's facing, how fast it's moving, and in what direction it's heading. Technique impacts every single one of those things.
    • There are clear technique things you are doing that will easily confuse the GS. But you're wrong above when you say it's spot on after the first few lengths. As evidenced by your stroke counts and lap times, the GS seems to have mis-detected many more laps than just the few that you point out at the beginning of the sets. You don't see it at first because the GS appears to have actually counted the proper NUMBER of laps in most cases, but it failed to properly detect where one lap ended and the next began. Look at instances where you had improbably fast laps with few strokes (20sec, 7 strokes) followed by longer-than-average laps with high-stroke counts. There's even one series that goes 10-7-13-7-13-7-11. Highly unlikely you'd have nearly a 100% swing in stroke count from one lap to the next over five laps.
    • The mis-reading of breaststroke - and potentially over-counting of strokes on freestyle - is likely due to a freestyle technique that involves some combination or all of the following 1.) Raising your wrist higher than your elbow out of the water then bringing it down forcefully before pushing it forward, 2.) Swinging your hand beyond your midline laterally (crossing over in front of your head) out front of your stroke, and 3.) using the typical "s-shaped pull" that many recreational swimmers use. The net result of these things is that instead of reading a simple "1-2" forward-backward motion, your GS reads something that looks like up/forward-down/backward-forward/in-forward/out-backward/in-backward/out. Could be one breastroke, two freestyle strokes, or god knows what.
    • Adopting a better technique will not only ensure better GS accuracy, but it will make you a stronger, faster swimmer.
    Take a look at swimsmooth.com. Their freestyle simulator is clear and intuitive. It's interactive on their website, but here's a YouTube video...
    http://youtu.be/IyR7JYllk9U
    And here is the technique with a real (Olympic) swimmer...
    http://youtu.be/s3HhNlysFDs
    I'm not "blessed" with good technique, I work at it. I've only been swimming for two years, and the biggest part of my success in this area has actually been using swim watches like the GS. My previous watch was even less forgiving than the GS, this revealed to me a fault in my technique rather than a fault in the watch. Once I started using that watch - and swimsmooth technique - my 100yd pace went from over 2:05/100yd (where you are) down to 1:40/100yd almost overnight. A year later and my typical daily swim is at a 1:28/100yd pace over 3,000yds.
    You're right about beating me on foot. At the age of 48, I firmly believe one should only run if being chased. (And even then, only fast enough to avoid being caught.)
    As to swimming, with the GS and swimsmooth.com I have no doubt that you'll be even with me in the pool very soon.
    As far as cycling? Well, I suspect that I'm more than few years older than you. But I won't hold your youth and inexperience against you. (I'm a far stronger cyclist than I am a swimmer.)
    Have fun, and do checkout swimsmooth.com. There’s enough phenomenal free information on their website that you won’t need to buy any of their training materials.
    :cool:
    Thanks to Damon for posing the question and to all for answering. I am having the same troubles but reducing them every time I swim by paying attention to my style. I found I was hitting my head with my arm sometimes in freestyle and back stroke, which the watch registered as a turn. Greater attention to the 11 to 1 position eliminated that. I found that it was less likely to miss an actual tumble turn if I didn't use my hand to assist the turn, rather, keeping it as straight as possible out front during the turn. During breast stroke a smoother hand motion, and using the non-watch hand for the push-off, gave 100% accuracy. Looking forward to improving my style through the watch feedback, and Ray, I never thought your post was pompous. All the best.
    Missing Laps -- Vivoactive
    Hello, I just got my Vivoactive and swam twice with it, each time 2,500 - 2,750 yard in a 25-yd pool. I found the same problem of missing laps. It seemed to work fine while I swim freestyle or breast stroke. It start missing laps when I swim IM. (missing 25yd at each 500yd intervals, twice ).
    Then it stopped counting laps when I used kickboard when arms were not moving. The whole 250 yard it shows only 25 yard. Is this typical? Can the watch track kickboards?
