Yes, that is very likely (and I already mentioned that in another thread). But any larger error caused by temperature would render the measurements useless unless compensated in software.
So I am pretty confident that the pressure sensor is either intended to be adequately insensible to temperature changes, or its output is corrected in software before being used for anything. In either case, you should not see any significant altimeter error from a temperature change.
