This has happened a few times where the activity from my forerunner 35 does not sync. I can see the activity on my watch just can't sync it to the Garmin Connect.
would you be able to help me fix another corrupt file C2685541.zip
Some fit files can be fixed by FIT File Tools, using the section remover without any adjustments. The result can then be uploaded to Garmin Connect Web using the Import Data page. I tested your file, so this works. Then change the activity type from "Other" to "Running."
This will work - New York Running-Fixed.zip
Some suggestions to help minimize the occurrence of corrupt fit files on a Forerunner 35
I have tried to do this and the file keeps saying not accepted by the system
I always test these before attaching the fixed file. Not sure what you're doing but just to check...
I am so sorry I attached the wrong file. C2C85134.zip
It looks like my Garmin won't sync again would you be able to help with this file?C3AJ2920.zip
1 timestamp with erroneous GPS data.
Fixed using Fit File Repair Tool - C3AJ2920-fixed.fit
C5660411.zipHello I am having trouble with another file
