did you get this problem fixed? .. 2020 - i have the same issue
Same here. Since yesterday after my run, my practically brand new FR35 quit tracking my steps and heart rate. Tried the fix dadiator used, and got nowhere.
I've also started getting this problem - after it working for 2+ years.
I have noticed if I run with my mobile connected to the watch it works and tracks steps when I run. As soon as I disconnect it…
My experience with Garmin support is that they are very supportive, and they will promise to help you, but then they never follow up with the cases. You have to be very persistent and pushy with them. I am not sure what your particular case is, and how long you had the watch for, but I expect that they will be open to an exchange more than a refund.... good luck.
This is the Garmin proposed solution and it worked for me. Hope this is helpful for you.
Thank you very much Garmin for the support!
Press & hold the left upper/power button for 30 seconds (Soft Reset) & then connect it to your computer.
See, via Garmin Express if there are any pending updates for the watch. Please follow the instructions below.
1. Open Garmin Express (can be downloaded at garmin.com/express)
2. Ensure that your device is the device listed in the top bar
3. On the Your Queue box, it will tell if a update is available
4. If updates are found, please click Install/Install All
Next, remove 4 folders from the watch, please follow the instructions below.
1. Open the device's drive in your computer's File Explorer(PC) / Finder(Mac)
2. Open the Garmin folder
3. Delete the Activities, Monitor, NewFiles and RemoteSW folders & GarminDevice.xml file
4. Empty your computer's Recycling Bin(PC) / Trash Bin(Mac)
5. Eject the device from your computer
Next, let the watch charge to 100%, wait for another 10 minutes, eject from the computer and restore
the defaults on the watch. Please click the link below for the instructions on how to restore the defaults.
