Just noticed there's an update available.
Changes made from version 2.40 to 2.50:
Addressed issue which can cause wrist heart rate to remain on a fixed value.
http://www8.garmin.com/support/download_details.jsp?id=9578
First I hope that someone from Garmin is monitoring these forums.
I have had my 235 for a month now and I have enjoyed using it. It has tracked my HR well during outdoor and indoor runs. The problems I have are when I am doing the "other" activity. I have been doing p90x3 and the HR will get stuck on 66. When I stop and adjust (tighten the wrist strap) the HR will stay the same or start to track downward. If I power cycle the watch the HR will begin to track correctly in the 140s to 160s. I have not noticed the watch getting stuck on the 66HR or having inaccurate readings unless I am in the "other" activity. I hope this information helps with problem solving. It would be great to not have to power cycle the watch every time I workout with the "other" activity.
Hmmmm, maybe think it's developed new bugs with 2.50.
Just had a steady swim of 4 laps, and when I finished looked at the HRM to see if it had come to life (didn't set activity), and it hadn't. So pressed the HRM widget, and it showed 82, then in the space of about 30secs went down to 72, then shot up to 154, then settled on 98, which would have been about right.
Are others experiencing this yo-yo effect?
Is that because it is still wet? Presume it doesn't actually "work" in the water for HR?
Just got my son a 235. Do I skip the update and just use old version? Seems you guys are posting issues.
My last two runs since the update have been pretty poor. Cadence lock/crossover issue quite apparent in the 2nd run
First was a cool down run. High HR from the outset. Even stopping dead did not fix it. It eventually righted itself but not before moving the watch to every conceivable position on my arm. At first I though it was cadence lock, but the two values did not quite match for portions of the run. I have no idea whats going on here but my HR should have been 151 or so max for this effort. From 10 mins on its ok but the start is rubbish:
https://connect.garmin.com/modern/activity/1023536772
The second run was an easy 10 mile run today. HR all over the place for significant portions of the run. GPS tracking not great and pace tracking not great either for small portions of the run. These were city streets, but the buildings were only 3 stories at most. I've run in these areas before and mot had these problems. I have GPS and GLONASS on. So for even a steady even paced run the HR is acting up. For reference today was a mild, breezy day and it wasn't raining - about 11 deg C:
https://connect.garmin.com/modern/activity/1026330424
I'll definitely be sending this watch back now. I have an RMA number, but I'm undecided as to whether or not to ask them not to send a replacement 235, but get a 230 instead. The convenience of the built in OHRM is outweighed by its unreliability when running. For some of runs I might as well have had no HR monitor. If I have to resort to using a strap the I might as well ditch the OHRM and get the difference in cost bak.
