Does anyone else get the missing hourly step and HR data? When it occurs, it's always where the has been some tracked activities during that time.
Inspired by this thread i've looked into my own 235/GC calories a little closer and am similarly finding nonsensical estimates for anything outside of my running activities.
For example, in both Garmin Connect and on the watch (to the degree that i can see), today shows:
Total: 17177 steps; 16.24km; 1476 active calories
GPS run: 10726 steps (from ave spm*time); 11.05km; 755 calories
Simple subtraction tells me that outside of my run for the rest of the day i had 6421 steps for 5.19km and 721 active calories. The steps and distance seem reasonable given my activity level, but i apparently burned almost the same number of calories doing this as i did running 11km in an hour! Note that my HR graph across the day otherwise looks ok and never got above ~90BPM (besides my run and a single short spike up to ~160'ish BPM right after i woke up <- the culprit?!?).
I had never noticed the strange calorie counting before because i track calories in MyFitnessPal not GC, which takes the steps and activities from GC but calculates its own calorie estimate, which looks much more normal.
Certainly a bug in the system somewhere. Has Garmin acknowledged it and that they are working on a fix?
Darren, I'm not saying that your figures are correct or not, but outside of specifically recorded activities can you accurately relate steps to calories? If wandering around the house doing chores the Garmin seems to miss a load of my steps as it apparently ignores a run of steps less that 10 to prevent false counting. But your HR will be over resting which could be adding calories.
..and yep, it looks like the 235 thought my HR was above well 100BPM for at least another hour after my run. That might explain the high calorie reading for the day.
It's much more reasonable to believe that I walked around for 2.78 miles (14.8 total - 12.02 running) via my 6,352 Daily Activity steps rather than 3.61 miles. This number sometimes is way off and sometimes only slightly off. It's not an exact doubling. But every single day I have a run, it's off by some amount.
