my new one edge 520 plus does not connect to windows 10 PC as mass storage device
Hi there,
I can see the device in Device Manager -> User-PC > Disk Drives -> Garmin Edge 5xx Flash USB Device. But no disk available in File Explorer, so I cannot work with files on the device.
It is only charging.
firmware version: 5.10
I tried couple of cables, including one from Garmin package.
Tried all appropriate actions from https://support.garmin.com/en-US/?faq=PsxSBlFqTL57tN38aI6m29
Tried to download and install Garmin USB drivers from https://www8.garmin.com/support/download_details.jsp?id=591#Instruct. My Windows 10 says that is not compatible with 64 bit OS version.
Tried factory reset as well.
Other devices including Garmin Edge 800 work like a charm with my PC
Please help, I need maps and routes on my device
    0 Former Member over 5 years ago in reply to aweatherall
    thank you. I just thought I missed something in the threads of the forum. Going to address it to Garmin support. Cheers
    FYI, just checked my garmin with friend's old fashioned Asus laptop, guess there was WIndiws 7 - it connected as mass storage without issues using lap button pressed!
    So the problem is Win10 USB driver cmpatibility with Garmin devices.
    I have raised a ticket to Garmin support, but in the meantime found a solution: Windows 7 x64 installation on VirtualBox. These Win7 drivers work for me. Probably can be useful for somebody. Ride on.
    I had the same issue with my girlfriend's refurbished 520 that she received from Garmin as a replacement when her original 520 croaked, but was out of warranty - I think they charged $50 for the replacement. I tried unsuccessfully using several usb cables. I had downloaded the usb drivers. I looked thru my piles of usb cables and found one that I got with an older Android phone that was used for data transfer. This worked when I held down the Lap button and connected to my computer. Maybe purchase a data transfer cable from Amazon or elsewhere - they are more expensive than a standard USB cable.
