Help with corrupt fit file
Might as well start a thread for this like they have over in the 500 forum.
I've only had my 520 for a week, and I really like it. The only issues I've had so far are that sometimes the bluetooth requires me to restart on the device to work properly, and then tonights FIT file is really corrupt so I can't load it over to strava.
The online FIT tool doesn't fix it, and then I opened it in golden cheetah. It seems the timestamps are all whacky, where it should be increasing every second, but it looks like the stamps are becoming integer overflows. The data is there, I just don't know of a way to edit all of the timestamps by just setting them as monotonically increasing seconds after they start getting corrupt in the file.
Any ideas?
    another in need of help
    this is a recovered file from my garmin, its corrupted can anyone help to fix it, i've tried myself but to no avail, this is the original file i recovered though, not one i've played about with, any help would be amazing!
    Hi,
    please look into your file!! (with a text Editor like Notepad++ or so)
    this is not a fit file and contains some astonishing information
    (the original file is still available?)
    Hi,
    I'm Confused as that was the file that was recovered from my garmin, basically the ride saved, then i looked through the summary and then as i was going back up to my flat the garmin shut down, i thought nothing of it, opened it up to sync with my phone and nothing happened, then checked the ride history and it was not there, used a recovery file software and found a file in activities, the same format as the ride should have been showing as date with - between and then time so i 'recovered it' in the hope of fixing it if it was corrupt. looks like something went wrong though i guess...
    is the astonishing info, something i should take off of the web then?
    not sure i'm going to get the ride back
    yes, I think so
    Me too please?
    My 520 jumped ahead in time nearly 6 months right after I started to ride. Grrrr :mad:
    Hopefully it is fixable. Thx to those who do this willingly and freely. You folks rock!
    ps tried some of the online tools first to no avail.
    Brett
    Evanston WY
    I have a corrupt fit file ...
    2016-03-15-17-56-10.fit
    because so far no one has replied, I've looked into the file
    was this an indoor ride? some data are implausible (e.g. GPS)
    from minute 16 to 24, the data are missing completely
    the repaired file works with WKO, Golden Cheetah and garmin connect
    I hope it helps
    Brett
    Evanston WY
    Hello Brett,
    Here ya go....An easy fix for the Fit File Repair Tool.
    Thank You very much Datezz!! Worked like a charm.
    Brett
    Evanston, WY
    Can someone please help me repair this corrupted file? I've tried to repair it without any luck.. Thank you :)
    Hello Mat,
    Your device lost satellite lock at the halfway point and when it got lock back again it had jumped the date to June 2027.
    So....here ya go. Fixed with the Fit File Repair Tool.
