Yes, the file system may not have been rebuilt! Am I reformatting okay, should the device stay on after disconnection ?! Am I correct?
Yes after disconnecting the device it should come on. I cannot recall if it rebuilds the file system before showing that it is on or if comes on and then rebuilds the system
All right! now the formatting is running when I'm done disconnecting and turning on the device! You have to wait a long time here before it is rebuilt if I think so !?
The formatting is done, I unplugged the device, turned it on and it's there again that Loading Profiles ... nothing else happens ..........
Let it try that for a while. If it does not move on from that send me a private message with your email.
It turned off automatically after a few minutes :(
moderator removed email address
gozpeti, I believe aweartherall is asking you to PM. Hover over the name then select "Send a private message."
You can then safely relay your email address
gozpeti did you solve ? i have the same big problem.
