It takes several minutes to reconnect to them all. I have Varia light/radar, Polar HRM, Garmin speed sensor and a PowerPod v4 power meter. It was also happening with v11 software update.
Same issue here with 12.20. Worse than 12.14 beta. Had all sensors lost and rediscovered 12 times in a 25 mile ride yesterday.
I have given up on trying to connect my Bontrager lights since that only causes…
This is very annoying on a ride. There was a section where the radar was toggling between connected and disconnected every couple of seconds for about 10 minutes. It was driving me crazy. My power meter…
Update. I followed the procedure to set Ant+ logging to on. I then did two long rides, (one ride of 5 hours, the other 3 hours). In both cases the problem did not occur. All sensors including radar were rock solid with no dropouts! So, now I wonder whether ant+ logging perhaps does something that solves the issue inadvertently. In any case I will report to Garmin CS and see whats next. For now I will leave the logging on, since it doesn't seem to do anything bad, and in fact perhaps fixes the issue.
Someone did post the procedure but it's been deleted. From what I remember....
In the last week I experienced sonsor drops, however, there was no "beep" so I saw that when I accidentally checked the screen. This is far not good. As additional problem the Garmin Edge 1030 more often need to re-add to connect IQ (my phone report that authorization is required to connect edge1030 via bluetooth to my phohe and I have chance to either click on canclel or OK, however both end up by diconnected edge1030 and the solution I found so far is to re-add the device which means garmin connect webpage will send me a congratulation to my NEW edge device)
Also a new "hidden feature" is the power off procedure which is more often hung up and screen remains powered on with a sign on that (power off sign). In this case I have to long press the power button and attempt to shutdown again. This sometimes resulted in a broken connection between device and phone and have to reinstall device into the connect IQ app again.
So whatever is happening it is getting worse. I'm not sure why a bluetooth/ant+ drop RCA and solution takes almost 1 month. It is acceptable in case of a 100 USD device but not in case of Garmin which is not cheap at all.
Concerning the power off sign remaining on the screen. I had the blue halo issue last year and the replacement Garmin sent had the power off problem and several other issues. I had to do several total resets of the device to get it to work properly. It has worked flawlessly since then and I have not experienced any loss of the four sensors with the current firmware. A reset might be worth a try.
