Hello everyone,
I use strava live segments and they are not displayed when navigating. If I drive without navigation it works.
Can someone help me?
Thank you!
(Edge 1030 Firmware 11.10)
Hello everyone,
Thank you!
I'm pretty sure that's the way it works UNLESS you design your route on Strava itself and download it to your Garmin. Very frustrating!
It is working OK for me.
If you view the course in Garmin Connect do you see the start and end flags for the segments
I feel it is worth mentioning that Ride With GPS can in fact export in the FIT file format -- and that is what I always use. But I also have found that course navigation overrides the Strava Live Segments…
I can’t get this to work at all. I created a strava route with segments, segments are seen in the route in Garmin connect but when navigating the route - nothing. No pop ups, no alerts.
Segments are on and work when not navigating.
Tryed with climb pro off or on, segments off or on. No difference.
Is there something special which has to be done when syncing Connect to 1030? Or any special setting?
If you sync using either GCM or Garmin Express that should generate a course file with the segments embedded and download it to the Edge.
Could you post the course file you got?
That is correct, it does. But segments still don’t pop up whilst cycling in navigation.
Are you using the same activity profile when following the course that you are when segments work when you are not following a course?
Yes.
I notice that if I go to training -> race and activity and pick a completed route, the map shows what looks like segments. If I go to navigate, courses, saved courses, and pick a stava route with segments, I can’t see them on the map.
So it seems like the segments get stripped off the navigation file when syncing. Garmin express says synced correctly but then immediately says there are items to install. When looking at them, they are the segments.
Have now turned strava segments off on Garmin Connect, and synced the 1030. But Strava Segments still exist on the 1030 when I look at the Training section of the menu.
I’ll add a screen shot if I can.
The course file just embeds references to the external segment file. So the segment files also need to be on the unit for it to work.
I would really like to see the course file so I can see what GC is sending you.
The segment description should come across
but the ID's appear to match
