New Edge 1030 Public Beta 10.22 Now Available
A new Beta software for the Edge 1030 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 1030 (10.22): https://www8.garmin.com/support/agree.jsp?id=12819
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 10.20 to 10.22:
  • CIQ 3.2:
    Added CIQ 3.2 support.
    Added BLE sync support for the Connect IQ app.
  • Indoor Training:
    Added smart trainer widget that includes Tacx Road Feel controls.
    Fixed course points for indoor trainer rides.
    Added the Virtual Partner to the map page when following course or activity on indoor trainer.
    Fixed issues with grade, power, and resistance controls for smart trainers.
  • Simple Setup:
    Added Simple Setup support. Port old activity profiles and sensors from Garmin Connect during initial setup.
  • Livetrack:
    Added device driven Livetrack.
    Added course sharing.
  • Radar:
    Added radar 'All Clear' tone. Setting is configurable in the radar sensor setting menu.
    Added instructions for pairing a radar in the radar sensor search menu.
  • Segments:
    Fixed recurring 'Deleting Segments' prompt.
    Fixed updating segment leaders on sync.
    Fixed segment completion bugs.
  • Improved reliability of FTP auto detection.
  • Fixed segment completion bugs.
  • Fixed crash when updating sensor software.
  • Fixed issue with smart eat and drink alert prompts.
  • Fixed false 'Climb Complete' prompts when riding a segment with ClimbPro.
  • Fixed retaining light network disable over power cycle.
  • Added support for metabolic calories in the activity file.
  • Fixed other minor UI bugs and crashes.
Installation Instructions
  1. Connect your Edge 1030 device to your computer using the micro-USB cable.
  2. Download and unzip Edge1030_1022Beta.zip and place the GUPDATE.gcd file in the \Garmin folder of your device's internal storage drive.
  3. Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
  4. If you would like to revert to the last public release software, follow the above steps but place the GUPDATE_1020.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
    NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
Top Replies
All Replies
  • In almost 2 weeks of using this Beta I have had this experience:
    1) VERY positively surprised by the ‘all-clear’ signal of the radar. Thank you.
    2) A bit disappointed that there is no support in this version for CIQ Workouts
    3) Today had a very strange experience, the only strange experience so far, but VERY strange:
    -> The 1030 did not show up with my workouts. After waiting for 5 minutes in the cold I gave up and used the old TrainingPeaks App on the device to download the workout of today.
    -> The start button resulted in a ‘beep’, but not the start beep and it refused to start the timer!
    -> I tried to turn off the device, but it said: “ Connect IQ app is open. Close the app before putting the device to sleep or powering off.” I never had this message and it prevented to shut down the device.
    -> Turning off my (i)Phone completely did not help. Even after the 1030 reported that my phone disconnected, I still received the above message.
    -> Did a reset of the 1030. After that it connected to my (also fresh restarted) phone and it showed my workout and asked to ‘restart’ it instead of ‘ ride’ .
    -> After that no problem.
  • Simple setup was introduced with the 1030 Plus, check reviews of that device for explanations. In a nutshell allows to transfer some settings from an old to a new device (data screens, activity profiles, sensors, etc). Having it in the 1030 will allows to transfer setup form that device to another one.
  • -> The start button resulted in a ‘beep’, but not the start beep and it refused to start the timer!
    Same here while using Komoot app.
    It was not possible to start the timer / activity and when trying to shut down the device, the same "Connect IQ app is open..." message popped up. I tried multiple times, alway having the same result. I was only able to shut down and restart the device by holding the power button for 10 seconds.
    By 'reset' do you mean a forced shutdown / restart by holding the power button for longer than 10 seconds? Or did you do a factory reset? Does the device incl. the apps work normally now?
  • Garmin shoud add an "force sync" or "sync now" button for routes , segments and workouts
    After sync, a page should display the info with latest route name , or workout name , that was copied to device from GC
