i sync and as soon as its finished syncing the garmin pops up with the message deleting segments then a second message pops up deleted all segments
I tried loading Garmin segments and everything works correctly. As soon as I try to set up the Strava Live Segments, it automatically deletes them from the device
There are 2 different things going on. One is a Strava issue the other is Garmin issues. The delete all segments looks like a Garmin issue. The Strava issue is that they are sending segments with no leaderboard contents. This results in strange behavior on the units.
Hi! I started having this issue a week ago and I was able to fix it (at least for me anyways). What I did was I got into the menu setting on my Garmin Edge > Device Reset > delete data and reset settings. After this is done, go to your Garmin connect app, click on your edge device and click on “forget device” option. Also, do not forget to delete this device on your Bluetooth setting. When all of this is done, just reconnect your Edge again as if it’s a new device.
please let me know (anyone really) if this worked for you. Good luck!
