Edge 1030 (v7.50) shutdown suddenly during activity
Zero problem or issues in the last months but today, with battery level at 82%, suddenly during my activity the Edge 1030 shutdown, without any reason.
Fortunately I was able to turn it on, and I don't know why, but it is in a state that ask me if to save the previous activity or restart/continue it.
I choose restart and in that way I've lost only 1 minute of data.
Anyone of you know what could be the problem?
  • Same. 1030 has been rock solid over 1,000’s miles. Updated to 7.5 three shutdowns/restarts in under 10 miles.
  • same for me, I have it from October last year , never had an shutdown , or at least I did not notice
    I think I did ~7000 km since then
    Yesterday in the middle of the ride  I start the navigation to an known address , after a while I notice that the screen was off
    I have checked and error is "RTL trap" , I don't have the Garmin with me but I will post more details
  • For the time being. What is the process to do downgrade?
  • https://1drv.ms/u/s!AgGAHuaBEk_sg9ojja18eRNIsEMyzg?e=m3S0l9
    Software 7.50
    Time":"2019-6-26 22:1:19"
    RTL Trap
    I was almost at the end of the ride , I tap Navigation to an address , I had the route calculated  , some turns then when I look at the screen , Garmin had an nice shutdown
    The problem is that I don't know what map I had selected
    If you need more help , please let me know
  • Was riding with a route (created on Strava and pulled onto the device using the Strava Routes IQ app). The Edge 1030 shut down twice during a ride (~52 miles) today. Debugging info attached.
    Edge 1030; software version 7.50
    Connected sensors: Garmin ANT+ HRM, Vector 3 pedals, Varia RTL510, Varia UT800
    Additional issues I've been experiencing with the Edge 1030:
    1. Weather warnings popping up between 3 and 15 times consecutively, multiple times per ride. Clearing dozens of flood warnings has been part of every ride (in KC area) for multiple weeks.
    2. Prompt to reroute popping up repeatedly if riding along a route in reverse, the entire time while doing so.
    3. Unit is unresponsive for a couple minutes during startup, which seems to be a new issue
    4. LiveTrack with auto-start enabled does not auto-start despite the mobile device (iOS 12) being connected.
    5. My original 1030 was replaced in October of last year due to the halo effect screen issue. The new unit appears to be developing the same issue now.
      Debugging.zip
  • Happened to me too. Did you check that Power/Battery Save is turned off?
  • What is the connection? shut down is a shut down, not power save.....
  • 2 shutdowns during activities since the update to 7.50 - didn't had this before... I was able to resume after a manual power on  - the error_log.txt file shows the following:
    "unit_id":"xxx",
    "product_name":"Edge 1030",
    "software_part_number":"006-B2713-00",
    "ms_since_epoch":1565511999000,
    "system_version":"7.50",
    "build_type":"PRODUCTION",
    "backtrace":"
    Function Address: 0x003FF14C
    Call Address at Function: 0x003FF168
    Function Address: 0x0074BB42
    Call Address at Function: 0x0074BD10
    Function Address: 0x00473818
    Call Address at Function: 0x00473834
    Function Address: 0x0019BAE4
    Call Address at Function: 0x0019BAF6
    Function Address: 0x0045650C
    Call Address at Function: 0x0045668E
    Function Address: 0x006F3E7C
    Call Address at Function: 0x006F3EA6
    Function Address: 0x006CB254
    Call Address at Function: 0x006CB60C
    Function Address: 0x00456A70
    Call Address at Function: 0x00456B10
    Function Address: 0x0033F59E
    Call Address at Function: 0x0033F5A4
    Function Address: 0x004547FE
    Call Address at Function: 0x00454828
    Function Address: 0x00190954
    Call Address at Function: 0x00190F72
    Function Address: 0x0018B01C
    Call Address at Function: 0x0018B13A
    Function Address: 0x0037AC9C
    Call Address at Function: 0x0037ACB6
    Function Address: 0x0064D364
    Call Address at Function: 0x0064D41C
    Function Address: 0x0010939A
    Call Address at Function: 0x001093B8
    Function Address: 0x0024DA14
    Call Address at Function: 0x0024DAB6
    Function Address: 0x0019D97C
    Call Address at Function: 0x0019D996
    Function Address: 0x00154B34
    Call Address at Function: 0x00154BAA
    Function Address: 0x004541F4
    Call Address at Function: 0x0045426E
    Function Address: 0x0044568E
    Call Address at Function: 0x00445694
    "error_cause":"RTL Trap",
    "proprietary_info":{
    "Commit ID":"82ee1ab1082731425c9f7c276bfeebba985d9131",
    "Time":"2019-8-11 10:26:39",
    "CDP_LOG":"494BD5,19BC59,49354D,1F2315,19BC59,1C8B89,1C0719,238BDD,2960A1,25E881,2960A1,26F6C5,26F6C5,273005,26F6C5,110019,26F6C5,20EB81,26F6C5,123D69,26F6C5,123D69,26F6C5,123D69,26F6C5,20EB81,26F6C5,123D69,26F6C5,123D69,26F6C5,20EB81,26F6C5,123D69,26F6C5,20EB81,26F6C5,123D69,26F6C5,123D69,26F6C5,123D69,26F6C5,20EB81,26F6C5,123D69,26F6C5,20EB81,4938A9,20EB81,4938A9,20EB81,26F6C5,1DE261,492B89,272FF1,49D37D,495D65,2D2BD5,19BC59,1C08BD,19BC59,1A3A79,2050DD,1F261D,1F2315,1F261D,2050DD,1A3A79,19BC59,1C8B89,1C0719,238BDD,1C0719,1C8B89,19BC59,196F11,1A3B95,1A3B95,48AE69,196F11,2960A1,25E881,2960A1,26F6C5,26F6C5,273005,26F6C5,48ECD5,26F6C5,123D69,26F6C5,123D69,26F6C5,20EB81,26F6C5,20EB81,26F6C5,20EB81,26F6C5,123D69,26F6C5,20EB81,26F6C5,123D69,26F6C5,123D69,26F6C5,20EB81,26F6C5,493F1D,26F6C5,123D69,26F6C5,",
    "RTL Error Number":"6E5D8024",
    "Error Message":"Data abort, system r0-15 + cpsr",
    "Task Name":"BTM background",
    "Saved SP":"01DC41F0",
    "Saved LR":"0042BAB5",
    "Saved PC":"003FF168",
    "R[0]":"6E5D8024",
    "R[1]":"00000001",
    "R[2]":"01DCF574",
    "R[3]":"01DC4464",
    "R[4]":"34D185A5",
    "R[5]":"17F17108",
    "R[6]":"00000000",
    "R[7]":"01D3C1E8",
    "R[8]":"00000103",
    "R[9]":"00000000",
    "R[10]":"00000000",
    "R[11]":"00000000",
    "R[12]":"00000000",
    "R[13]":"00000008",
    "R[14]":"01DC41F0",
    "R[15]":"0042BAB5",
    "cpsr":"003FF168"
    Garmin, please invest into this and help :-)
  • This happened to me last night, for the first time.  Coincidentally, battery level was 82%. Repeated attempts while riding to restart failed. As soon as a valid operating screen appeared, it went full black, then white screen, then shutdown. Left it for 15 min or so, and it was fine from thereon.  Looks like the same RTL Trap is the issue.
    "unit_id":"398773xxxx",
    "ms_since_epoch":1567709967000,
    "backtrace":"
    Function Address: 0x0010E790
    Call Address at Function: 0x0010E7D2
    Function Address: 0x0029EC88
    Call Address at Function: 0x0029ECD2
    Function Address: 0x005CF2CC
    Call Address at Function: 0x005CF314
    Function Address: 0x003B1E24
    Call Address at Function: 0x003B1E32
    Function Address: 0x00727AD8
    Call Address at Function: 0x00727AF2
    Function Address: 0x005DF1EC
    Call Address at Function: 0x005DF274
    Function Address: 0x00765134
    Call Address at Function: 0x007651AA
    Function Address: 0x0059FBE4
    Call Address at Function: 0x0059FD72
    Function Address: 0x007276B8
    Call Address at Function: 0x007276D2
    Function Address: 0x006AB088
    Call Address at Function: 0x006AB0BE
    "Time":"2019-9-5 19:59:27",
    "CDP_LOG":"494BD5,19BC59,20EB81,1DE261,20EB81,",
    "Task Name":"mtk66xx_osal",
    "Saved SP":"024BF068",
    "Saved LR":"0010E7CF",
    "Saved PC":"0010E7D2",
    "R[0]":"6E5D8024",
    "R[1]":"6000001F",
    "R[2]":"6000001F",
    "R[3]":"00000000",
    "R[4]":"34D185A5",
    "R[5]":"0000001C",
    "R[6]":"00000000",
    "R[7]":"0000007B",
    "R[8]":"024BF190",
    "R[9]":"00000000",
    "R[10]":"00000000",
    "R[11]":"00000000",
    "R[12]":"00000000",
    "R[13]":"00000000",
    "R[14]":"024BF068",
    "R[15]":"0010E7CF",
    "cpsr":"0010E7D2"
