New Public Beta 6.46 Now Available
A new Beta software for the Edge 1030 has been released. Full change log, instructions, and software for installing the beta can be found here.
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
[h=4]Changes made from version 6.45 to 6.46:[/h]
  • Fixed several crashes that could occur while riding with a power meter.
  • Fixed segment updates.
  • Fixed issue where the GPS data field did not match the GPS indicated by the status bar.
[h=2]Installation Instructions[/h]
  • Connect your Edge 1030 device to your computer using the micro-USB cable.
  • Download and unzip Edge1030_646Beta.zip and place the GUPDATE.gcd file in the \Garmin folder of your device's internal storage drive.
  • Disconnect your device from the computer, approve the update on the Edge, and wait for the update to finish.
  • If you would like to revert to the last public release software, follow the above steps but place the GUPDATE-630.GCD file in the \Garmin folder. Rename the file to GUPDATE.GCD before disconnecting your device.
    NOTE: If you revert to an older version of software, all of your settings will be reset to defaults.
