Firmware 6.30 Bug
6.30 update has brought following bugs:
- shut down during ride (first time with my device)
- Vector 3 screen doesn't show datas
- Cadence sensor field doesn't show data
- GPS accuracy really sucks
I'm getting fed up with this device. For the first time I consider to sell all my Garmin stuff and go to another brand.
  • I have also Wahoo Bolt , is the same s...t regarding firmware's , as they brick a lot of devices with the last firmware
    Related to GPS accuracy , did you sync your device with wifi or Garmin connect ? As far as I know there is an EPO file that must be updated
    Seems pretty accurate to me:
    https://www.strava.com/activities/1887552500
    I don’t think perfect device exists but my old 1000 wasn’t as faulty as 1030 device.
    I didn’t know there were a difference between sincyng with Wifi or Garmin Connect. Can you give me the link to this EPO file?
    I still think there’s a issue with GPS as my device loses satellite very often.
  • Today's ride wasn't better than previous. Sensors stayed connected but lost connection with iPhone (iOS 12) around 30min after start. Shutdown after about 5 hours.
    GPS still inaccurate.
  • I am courios, this was the reason for upgrading my 810
    Edge 1030 is damn accurate in challenging areas, can you give an example for innacuracy ?
    Ps: You have to connect you Garmin device trough usb cable and check the folders , check the date for epo file(i dont remember the path)
  • EPO.BIN is under GPS folder. The date of the file is : 10/13/2018 1:14PM.
    You can find different samples of inaccuracy for yesterday and I have a lot more to share for yesterday and every ride.
