Corrupted FIT file activity
Hi, I had a ride yesterday and when I finished it my Edge declared on a new elevation record and stopped responding. After a minute I understood this is not going anywhere and none of the buttons worked so I did a reset by holding the power button for a couple of seconds. After that the activity wasn't uploaded from the device and even though I can see that I made this ride (see the time and distance) I can't get into the details of it. When I came back home I tried to upload with the Garmin connect but I got a message the file is corrupted so I tried to use some Fit file fixers over the net but none of them seems to fix it in a way that I will be able to upload it to the Garmin connect (even though one of the fixer created a file that allowed me to upload to Strava with a small missing part at the end of the activity - I tried http://garmin.kiesewetter.nl/ - Failed, https://www.fitfiletools.com/ - File was good for Strava but not for Garmin Connect).
Any other suggestion how to fix it so I will be able to see the activity in Garmin connect and in the Edge itself.
    0 Former Member over 4 years ago in reply to Pim.fr
    a monstreous task
    your file ended abruptly and was missing the summary part at the end
    two versions,
    a cleaned one and an original, repaired with help of FitFileRepairTool
    original
    original-97T93654-fixed.zip
    cleaned
    cleaned-97T93654-fixed.zip
    happy & safe hiking
  • wow !
    So quick and working !
    I donnot understand what happened athe end of the record...
    Just perfect. Thank You.
    I keep a beer at fridge when you will pass near Paris ;)
    Pim
    thx Wink
  • Legend! I hope you are getting paid by garmin;)
    Thanks.
  • Disappointed I just lost all the post I was typing.
    grrrr....
    1_ Sorry but *** happened twice but OnlyTwo (I hope !) :)
    2_ This time no GPS wild but a message when I tried to resume my paused activity close to be back.
    "No more space , delete old activities"
    -> There was no more activities...
    -> at home there was 300ko free space with a file about 480ko
    3_ When I get this message, I decide to end the activity
    -> I get the summary well displayed, I clic next
    -> Watch was stuck in a "Loading..." loop, no activity in Strava
    4_ Synchronization is ok with GC but some data are full of holes and no activity "Hike"
    5_ After 1h looping, I clic on a button and loop broke, get back time display.
    Theses are my firsts tries on the field with Strava, not lucky for now.
    Next activity, I will try without Strava and my recorded paths just in case STRAVA is guilty.
    :insert a gif of crying cat and Lillo asking "please help":
    Here is the file online for 2 days
    http://gofile.me/6Dt4B/ZoP41ls39
    Confused
    Thank you again.
    Pim'
    that is the most frustrating thing in life apart from loosing a lot of workout data Slight smile
    recording to the fit file ended abruptly and repaired with help of FitFileRepairTool
    14km is what remains of data in your fit file
    did not clean it up this time Slight smile give a yell when in need for a cleanup
    question : how many free space is available on your watch ?
    time to clean up fit files or start with a clean setup again
    pimfr-F5-kaput-98293613-fixed.zip
    happy & safe hiking
  • Sorry for the late reply.
    I bought a fridge to put your beers but I hope not to use it only for this purpose :)
    File worked well as usual.
    Yesterday an activity worked also well without Strava but still get a space low message...
    Used 53,8Mo
    Free 384 Ko...
    In fact all the problem is here, why I have so low free space with just Strava on the watch...
    I look into wit Treesize and I finaly ound out what is the  "#@!'"é~é" problem...
    I charged once my watch on my ISP box (Freebox) which has a front USB port... and this dumbass generate a file to recognize the device as usb key... This file buda_vfs.img, found and visible only with treesize, is 43,7 Mo weight !
    KILL IT ! BURN IT !
    \o/
    Pim
    nice story Slight smileSlight smile glad you sorted out that one
    you too earned a beer now
    happy & safe sporting
    Can someone help me with this one?
    First ride with V7.85 and I got a corrupt fit file.
    5488.2019-08-15-07-58-02.fit.zip
