Wrong Temperature
after few days of use I've seen 1030 temp value are constantly higher than real (and 520/1000 too). This difference is about 4 'C. A little few at about 25 'C (3,5 'C), and a little more near 0'C (4,5'C). Today I put 1000 and 1030 in refrigerator and they red 5.0/9.6 'C
  • Hello everyone. Thinking a little, if Garmin does not solve the temperature problem. You can make a new data field that is: Garmin temperature = temperature -5. And that's it. Let's see if any application programmer does it. I invite you to have lunch in Spain
  • The temperature offset on the Garmin Edge 1030 seems to increase the colder the air temperature gets. I noticed it was reporting 2-3 degrees C too high in fall/autumn temperatures of 10-20 C. In Winter temperatures of 0-5 C, I'm seeing about 5 degrees C too high. Come on Garmin, this is not a complex problem to solve. Even if it the error is non-linear, it seems to be pretty consistent, so it should by easy to incorporate a correction algorithm into the next firmware update.
  • I am also experiencing this. Just upgraded from a 1000 last week. My temp readings read higher than actual. I hope this gets fixed. I would like my data to be accurate for such an expensive device.
    Not surprised though. It is Garmin.
  • We are working to correct the temperature differences some users are experiencing ASAP. We value your feedback and continued discussion about your concerns.
    Thank you.
    Can you get my Garmin Remote working too? Winter riding is where I really need it and it's been pretty useless with the 1030.
  • Working on getting the remote issues sorted as well.
    "some"? I would say... all of them
  • FWIW: I rode 40 miles today with a friend who has a 820. The temps were 18-22 F during the ride. My 1030 displayed 30 F when my friend's 820 displayed 20 F. His was correct. Mine was way off.
  • Hoping there's a software fix for this (and that it's not a hardware design issue). My 1030 is also regularly registering temps that are way too high. The range is tough to pin down--I've regularly seen variances of 5-12F from a friend riding with an 820. I'm puzzled at the posters who are trying to convince us that this isn't important. Temp is most definitely an important cycling metric--I always appreciated this data point on my old 800.
  • Another way is to pair tempe sensor with 1030 ! Why is not possible ?
