Auto sync over wifi not working
Hi,
my forerunner does no auto-sync data over wifi, wifi networks are saved, option to auto-sync is enabled, but no data appear on garmin connect web like stress, sleep and other data until I go in the watch to wifi settings and manually hit "sync now", then all data appear on garmin connect web. Is any way to fix this, my firmware is 23.20?
  • I didn't say I wanted a sync every 10 seconds, but that it takes about 10 seconds to sync over wifi ;-)
    Haha yeah I was gonna say that wi-fi syncing already takes 10 seconds so syncing every 10 seconds would be aggressive. Sorry for misunderstanding.
    Once every hour would probably be negligible, but then again it might not be fast enough for most people.
    So far I'm at the stage of contacting the support, but they don't even have the knowledge I've learned from you guys here on the forum that sync via wifi only happens when the activity is done and saved. So they told me to check if the auto-sync option is checked on the watch, or to reset the watch ;-)
    Yeah that sounds frustrating but it's not surprising.
    Well, I'm waiting with the hope that something will change, thanks for your help.
    No problem, good luck!
    Have you guys actually measured how much keeping bluetooth off helps the watch and phone battery?
    I haven't measured it, but I def noticed that the watch battery drains faster with bluetooth enabled if I leave it on when I go for a run. (That's usually when I pay the most attention to my watch's battery life.)
    I haven't really looked into the battery impact on the phone.
    I don't use smartphone features (i.e. notifications), so I don't really have any need to keep bluetooth on all the time. I just turn it on if I want to sync without wi-fi or to use certain features which require it (like changing CIQ app settings or using features that need internet, like selecting content to sync in Spotify).
    You could use a CIQ app to track battery life on your Garmin device:
    https://apps.garmin.com/apps/a9c9b981-1f4c-4399-a270-7d6c7317893e?tid=0
    https://apps.garmin.com/apps/923cd514-fe15-476c-855e-26846d2007ec
