During the last night's this is what my HRV readings look like.
The data is getting inconsistent because of this. Is anyone familiar with this problem and might know of a solution?
All,
Thank you for sharing your concerns regarding HRV gaps. We are still investigating reports, but have still determined that the gaps are due to restricted blood flow. In case you missed my comment…
This is what Garmin has said about the problem on the bug report thread (forums.garmin.com/.../18-15---intermittent-hrv-measurement):
"We have been investigating similar reports and have a fix coming in…
All,
If you are experiencing this, please respond with the following so I can add you to our investigation:
1. May I have permission to reach you via email?
2. May we have permission to view your Connect…
I have the same issue. Reset didn't help :-(
Garmine problém už trvá příliš dlouho na to, aby byl stále přehlížen buď tuto funkci velmi rychle odstraň, nebo urychleně oprav chybu, protože tahle metrika nabízí ostatní metriky a díky chybě VST jsou všechny metriky k ničemu. Každý den je můj graf VST obrovské mezery viz. obrázek
I also have the same issue. Is there any update?
weird thing is that I don’t see gaps in my watch graph
Ahh it looked like a 955 like mine, there must be a subtle difference for some reason.
It must be a Connect sync issue if the watch data is fine.
First try resetting the home page tab; scroll down to Edit Home and again to Reset Home. Sometimes that fixes these issues.
Otherwise, remove and repair the watch to Connect. Might not fix the historic data but hopefully fixes it in future.
