During the last night's this is what my HRV readings look like.
The data is getting inconsistent because of this. Is anyone familiar with this problem and might know of a solution?
All,
Thank you for your continual input and examples of HRV gaps during sleep. After further investigating these reports, we've determined that the gaps are due to restricted blood flow. Please see the…
This is what Garmin has said about the problem on the bug report thread (forums.garmin.com/.../18-15---intermittent-hrv-measurement):
"We have been investigating similar reports and have a fix coming in…
All,
If you are experiencing this, please respond with the following so I can add you to our investigation:
1. May I have permission to reach you via email?
2. May we have permission to view your Connect…
I have the same issue. Reset didn't help :-(
Does anybody found a solution? My readings are getting worse and worse. It can't be that we cannot raise a bug or something to just make the engineers notice that this is not working properly.
Anyone find a solution for this?
Mám stejný problém a tak jsem začal testovat a zjišťovat proč a bohužel myslím že tenhle problém se bude těžko odstraňovat protože jsem svoje 965 na noc půjčil manželce a její graf VST byl naprosto v pořádku . Vzal jsem si její nové venu3s kde je novější elevate5 a bohužel moje VST mělo stejně mezery jako u vás na obrázku takže jediné co mě napadá může být problém když je VST hodně vysoké já mám kolem 105 a nebo třeba může souviset s nízkým tepem v noci padám pod 35 tepů jinak mě nenapadá proč se tenhle problém děje jen některým lidem a je jedno na jakém zařízení
That is actually a good reason... I have the same problem as you! my RHR is 35, and my HRV if measured correctly is above 100s... I have a Fenix 7s Pro SS which was replaced but the issue is still the same...
Garmin-Laurie / Garmin-Sierra what would be the solution for the cases as this? Where can we get hold of Garmin to fix this in a new software update?
Hi I am still having issues but I have a new insight. The graph is showing no line in connect while I do have most of the measurements in.
Why is behaving like that? Why not including a dotted line to connect those points at least as the watch does?
Have had the same issue for the passed 3 months had bloods and all done. Figured out it was the watch. Garmin are getting a refund sorted. But I like my forerunner 965.
Had my watch replaced as well. Nothing changed. Just FYI its a software issue which Garmin won’t change, so just keep your watch
