Interesting write-up by DC Rainmaker, with his thoughts on the root cause: www.dcrainmaker.com/.../garmin-watches-are-crashing-when-trying-to-start-gps.html
The astonishing fact about this whole problem is, that there is no error handling implemented for a file which is not even crucial for the functionality of the systems.
Hopefully it is now in the top 5…
Be that as it may, good software should not allow an entire device to get crippled when a file related to a limited function gets corrupted. I still believe Garmin software team is utterly incompetent…
Interesting, wonder if it could be related to decommissioming sat. SVN45 (PRN21) yesterday and an invalid CPE having been generated:
I can send you those two files which caused many people around the world to suffer data lost.
All you have to do is to connect your Watch to PC and copy those two files to GARMIN\RemoteSW folder.
As for test - hope this should be safe now.
You can connect your Phone to PC and use Garmin Express to sync your Watch?
At the same time have open File Explorer and watch this GARMIN\RemoteSW folder.
I guess you will see two files GPE.bin and GPES.bin
If you not unplug cable and kill, not only close Express app you should be able to delete them to be extra safe. I can tell you that earlier today when I have boot loop I have also Ephemeris: Current message. Unfortunately I cannot say what was during boot loop, but I guess something else.
Garmin has deployed new version of those files which fix problem, but I guess there will be changes in next FW too, to prevent this from happening again.
I started the activity around 10:30 UTC. Watch was connected to WiFi and to the Phone via Blutooth all the time. I also had the Connect App opened before, but of course I cannot say if it synced exactly this files before.
Another option is that the broken file versions were not released at the time when I was starting my acitvity.
