No more Map Themes on 955?
I wanted to install a custom map theme on my 955 Solar (newest firmware). Although I can put a .kmtf file in the Folder Garmin/MAPTHEMES I don't see the option under Map Settings. As the garmin manual states I should see a option Map Themes under maps but there isnt any. Did they disable this function or the possibility to use custom map themes?
Thx for any hint.
  • I just checked this and Activity Type is missing, it starts with Map Type. I don't understand this but it may be a regional firmware difference. Anyways :) Custom map themes seem broken as is high contrast. Brilliant.
    You also may check out these maps: https://ravenfeld.gitlab.io/open-garmin-map/
    Mine are tweaked for more contrast, thicker lines etc. But I only started with Europe so far.
