Swim rest screen
Regarding the latest update and the following:
- Improvements to the pool swim rest screen and alert tones.
Is there anyway to change this back to default. the way it is now is black numbers on a brown background, for someone like myself with not the greatest short vision I cannot make it out at all. Would prefer the old white on black like all the other fields. I mostly swim at night so not sure if its ok during the day time.
Interested to hear others thoughts.
Thanks
  • This just happened to me today on my Epix Pro. In my case, it is white numbers on a yellow background. Totally unreadable in the pool, and the rest timer & repeat on are the two that I most want to read when doing intervals. I tried creating a new screen with those fields, but they are always like that. While I love my Garmin, I hate it when they make it worse!
  • A small workaround I have used is to create 2 data screens:1 which only has the Repeat on field. With 1 field only I can now see this and it allows you do do your reps at whatever your desired depart time is ie every 1:30 or every 1:40 etc, and my 2nd screen has the int time and other fields that do not have to highlighting around them.
    However: hoping that gramin will soon remove the highlighting !!
  • It's horrible.  I added the rest field to another screen and made it the largest field.  Sufficient but absolutely nuts that they actually looked at this and thought it was okay.
  • I am having the exact same problem on my brand new garment phoenix seven solar pro.That I spent nearly a thousand dollars on just for swimming.I can't believe how bad it is
