Credit card pin - touch screen entering problem
Hello,
after penultimate OS update of Forerunner 955 began some problem with entering the pin when unlocking the credit card. Currently I am unable to enter it via touch screen because it always causes an error. When I enter it by buttons it unlock passes correctly. Nothing else was changed, just updated the OS.
Can you help me please?
Thanks, Tomas
  • I just received an Enduro 3 this week and set up Garmin Pay. When I try to enter then pin it rejects it  as the wrong pin. If I use the touch screen to rotate the numbers into the select area and then push the button it works. If I just use the buttons, it works. I'm not having any other inaccuracy with the touch screen anywhere else. C'MON GARMIN!!! Garmin,,,where everything just almost works correctly. This stuff doesn't happen at  Apple, just sayin....
